Chevette Motor Bases
16 years 5 months before #6828 by manual-mecanica
Chevette Motor Bases published by Manual-Mecanica
I need to change the engine bases of my chevette year 87, now I do not know how to let them go from the bottom, the nut is very scholarship, what I want to know is if I need a special key for that nut or the base is completely downed.
16 years 5 months before #6843 by manual-mecanica
Manual-Mecanica Response on the Re: Motor Bases Chevette
It is not necessary to hold it from the carter, but before that I release the two tacos below and then take the above. In some models you have to take out the coil and housing from the filter, because it covers you and bothers you a lot. greetings
16 years 5 months before #6844 by manual-mecanica
Thanks, I'm going to try
