Help with a 2000 Dodge Neon !!!
16 years 4 months before #6887 by manual-mecanica
Manual-Mecanica Answer on the Re: Help with a 2000 Dodge Neon !!!
I mean if the points of the follow -basis and the tree of lavas are well, everything should go
16 years 4 months before #6907 by manual-mecanica
The vehicle gives you a problem or is well?, after the water accident you deleted the computer memory, it can be a stored fault code and not a new one, the magnet captor or sensor of the crankshaft, or the one that is mounted on the cams, when the vehicle does not work does not work, there is no current in the coils.
16 years 4 months before #6919 by manual-mecanica
Well, if I deleted all the codes that I threw me that it was that but when the codes were erased after minutes later I turned on the check Engine code and repeated the steps of checking it with the computer (Scaner) and I continued to send that code that the time chain had jumped a tooth or two, and so it was re -check the chain of time From the camshaft or the crankshaft sensor one of the two is failing because I have understood if the crankshaft sensor failed did not turn on the bone car did not send the start, apart if it was out of time the temperature will increase already this car does not happen to him any of that: S : S: s the only thing that I have noticed that it is very common when they are very common when they are very common when they are very common when they are very common when they are very common when they are very common when they are very common when they are very common when they are very common when they are very common when they are very common when they are very common.
14 years 8 months before #16667 by manual-mecanica
I think they didn't synchronisted the conceanes well, it gives you fault code
