The air conditioning regulator does not work for me
16 years 5 months before #6864 by manual-mecanica
The air conditioning regulator published by Manual-Mecanica
Hello, I would like to know if anyone knows how I can solve the following problem:
when I try to regulate the air conditioning, it does not work, it only works when the wheel turns to the number 4. What can I do?
The vehicle in question is a Scenic of 1999.
Thank you.
16 years 5 months before #6868 by manual-mecanica
Manual-Mecanica response on the Re: the air conditioning regulator does not work
: Woohoo: Look usually the speed resistance is damaged. This model manages a mechanical one. What is genically damaged is a diode that goes in the resistance, a bridge is in the diode and the four speeds will work again what the resistance passes manages the first three and the fourth is direct of the control of the A/C to the blower motor
16 years 4 months before #6877 by manual-mecanica
It is correct what Gaudencio says05, the fourth is direct and in all models and brands when this happens is the fault of the rule or change or the bridge is your decisions
16 years 4 months before #6883 by manual-mecanica
Manual-Mecanica Response on the Re: The Air Regulator does not work for me
Thank you very much Gaunndencio and Kikemec but if I punctuate the resistance will continue to function the different types of air speed?
16 years 4 months before #6884 by manual-mecanica
It is worth now I understand it, taking off the diode and strucking it, I will work for me, but can you say where they are? Is it that I am a bit lost, that they are in the same incorporated speed regulator?
