Problem with Cavalier 93
16 years 5 months before #6872 by manual-mecanica
Problem with Cavalier 93 posted by Manual-Mecanica
Hello everyone, I could help me I have a cavaalier 93 I just bought it to restore it the problem that I now gave me is that being in motion when the directional lights or the intermittent lights feel a low power in the engine this low power is also felt a bit when turning the direction is heard as if it went to turn off. I tell you that the car is electric and apart from new battery then I don't know what is failing thanks a cordial greeting : Woohoo: : Woohoo:
16 years 4 months before #6880 by manual-mecanica
Manual-Mecanica Response on the Re: Problem with Cavalier 93
How Electric Everything?
16 years 4 months before #6881 by manual-mecanica
If the problem is a low power and it also happens to you with the lights you should check the alternator, I want to have any problems.
16 years 4 months before #7171 by manual-mecanica
After checking the delivery of energy to the system you should give idle learning or re -enanza from idle, disconnect your battery for approx 10 minutes, then connect it again and put all the electrical elements to work, for example, light the lights, the radio air conditioning and the most important thing of the entire emergency brake, you must leave it in the position of the gear. 15 minutes of leaving it so turn it off and turn it on, with this you have the calibration of idle mnima.
I also recommend that you do a cleaning of the IAC valve before teaching it.
Good luck with your coic we are in contact.
