Citroen Ax Electrical System Problems
16 years 4 months before #7195 by manual-mecanica
Manual-Mecanica Response on the Re: Problems Electrical System Citroen Ax
You change some bulb, it may not have put the right apart can also be that some of the rear headlights do not have enough ground discharge and this defect is turned on any light on the board also or not.
