I have to throw direct benzine to the carburetor
16 years 3 months before #7462 by manual-mecanica
Hello friends I have a problem every time I have to start the car I have to throw a bench tap to the carburetor so that this starts my car is a renault 11 hoods year 1985 please help me :(
16 years 3 months before #7463 by manual-mecanica
Manual-Mecanica response on the Re: I have to throw direct benzine to carburetor
From what you say I would check the bomb and the carburetor chicler, you combine do the complex chrburador, do you have a mechanical or electrical bomb?
16 years 2 months before #7525 by manual-mecanica
I have a mechanical bomb
16 years 2 months before #7534 by manual-mecanica
Look for what you say, your problem for me is clearly the carburetor but if your pump is mechanical and you have problems for example in its notes that the vehicle does not throw hard, you must change the pump is not expensive and if you have never changed it, it must be the main clear problem that you must check the carburetor anyway. Hose that arrives at the carburetor from the pump and asks someone to start fuel immediately, if it takes more than to communicate it then change it.
16 years 2 months before #7551 by manual-mecanica
Thanks for the answers
