Peugeot 205 xs alternator
16 years 2 months before #7754 by manual-mecanica
Peugeot 205 xs alternator published by Manual-Mecanica
I have a 205 xS Peugeot, when I start it, after a while the engine is turned off, I feel a lot of naphtha smell and I feel the engine that begins to vibrate more usual. At the same time, the lights go down, and if it accelerates it, the tension rises. I thank you if you can help me! Greetings!!.
16 years 2 months before #7757 by manual-mecanica
Manual-Mecanica Answer on the Re: Peugeot 205 xs alternator
Hello, regarding what you say is more likely that you have a damage in your alternator it would be good to verify the load system with your electrician, then the engine with your mechanic because if the alternator is failing the machine does not have to go out.
16 years 2 months before #7796 by manual-mecanica
Thank you very much for the answer! I tell you that I was running out of battery last night. Thank you very much again !!! All the best!
