ECU in emergency
16 years 2 months before #7787 by manual-mecanica
ECU in emergency published by Manual-Mecanica
Hello Friends of the Forum, I have the Astra Turbo Diesel of 16V that puts the ECU in emergency, the Scaner accused me of the EGR valve changed it and the problem continues. My question is: can I do something to the ECU to get it out of emergency manually with a bridge or connection? A hug.
16 years 2 months before #7804 by manual-mecanica
Manual-Mecanica Response on the Re: ECU in emergency
Tell me that ECU is andq Diesel system is, if the diesel system is BP 44 or see EDC
Aver if I can help you I wait for your info greetings :)
16 years 2 months before #7813 by manual-mecanica
It is a BP 44 system a hug
16 years 2 months before #7814 by manual-mecanica
Another question did you use the original scan or the scan of Bosh and the car apart from the liglas of Fallas Lost Fuersa does not start or only the light on the board?
16 years 1 month before #7828 by manual-mecanica
The "emergency" mode is an alternate program that is activated when the diagnostic system detects a failure that could compromise the emission control system ... This TA program gives a minimal vehicle maneuverability so you can take it to the repair workshop. If the fault is not repaired, it will not leave the support mode; I do not advise you to make bridges, you could damage the ECM
check the pipe that the exhaust multiple with the EGR valve as sure that is covered with carbon and also clean the tube that connects the EGR with the multiple of admission, if the fault is repaired after three complete cycles of handling the ECM automatically detects that in the EGR system there are no problems; will turn off the indicator a thousand and leave the backup program. If you need more help, let me know
greetings
