Help get megane flyer
16 years 2 months before #7815 by manual-mecanica
Help get megane steering wheel published by manual-mecanica
Hello, I have a poor thing is that the windshield wiper does not work for me and we do not think it is the handle and I wanted to change it and removed the tapas, but I see that it does not come out, that I have to take out the steering wheel, I realize that there are two haleen type screws
16 years 1 month before #7827 by manual-mecanica
Manual-Mecanica Answer on the Re: Help Take MEGAN
Be careful! If the steering wheel of your car has airbag, do not release any screw and even more do you disconnect any terminal whose protection is yellow, the air bag can be activated and cause a serious accident. Disconnect the battery cables (the 2) and wait for at least 5 minutes to download the backrest capacitors of the ECM of the airbag (the manual says a minute but for a perhaps ????) Then if you can disconnect all the terminals.
The screws that you say are those that hold the center of the steering wheel, also verify that there are no plastic covers on the back, if there are withdrawal and also the screws that there are there. There is a flexible in the center of the steering wheel, before disconnecting it, it writes its position so that it assembles it in the same way .... When you transport the airbag do it with the decorative element towards brought and separated from the body, do not let it fall and store it in the same way with the decorative element upwards
16 years 1 month before #7830 by manual-mecanica
Thanks, to change the handle, there is some way to change it without taking the steering wheel
greetings
16 years 1 month before #7832 by manual-mecanica
The contactor (what your flames Maneta) is a single piece and is attached to the base of the steering wheel axis and also the steering wheel axis passes through it. It is necessary that you remove the steering wheel and also the tapas that cover the column of the direction, you will see some screws and you have to release them all. Once it was only one that you can do is check if it is not broken any piece or some wire disconnected, disassemble it I do not advise you unless you are enable with the small parts and electricity of electricity since it has a neck I spend and learn ... that in the end it is what matters ... if you take it out and disassembly let me know what is and if possible a photo, could help you.
Good luck
16 years 1 month before #7842 by manual-mecanica
me the same pulls water but you clean what you can have, a few days ago we check the engine plug in direct current and moved in toria the engine is going well
