FIAT FIORINO FAILURE CODE 1.5E
16 years 1 month before #7909 by manual-mecanica
FIAT FIORINO FAULT CODE 1.5E Published by Manual-Mecanica
Hello everyone, I have a failure in the Fiat Fiorino 1.5E (gasoline), year 2000 and desire indicate how I can obtain the computer failure code manually. Is the "scanner" necessary? Someone told me that it can be obtained in a similar way to the OBDI systems, if so, how can I get it?
16 years 1 month before #7936 by manual-mecanica
Manual-Mecanica Response on the Re: Fiat Fiorino 1.5E Failure Code
Look, you can get manually but you must bridge some pins of the diagnosis tamo, now You want to solve the problem. Greetings
PD: If you have access to the Autodata, give me the complete data of your vehicle, brand model and displacement brand to see how the bridge to realize sends you.
16 years 1 month before #8170 by manual-mecanica
Thank you Kikemecor your prompt response, the data of the VIN 9BD255229x8662962, year 2000, Fiat Fiorino 1.5E 1500cc
itself the failure is when the engine is cold or reaches the point of higher temperature (before the fan begins to cool the radiator (I have related it to this).
Replace the thermostat, the temperature sensor and even the failure.
When I go in normal, without long stops the failure light goes
out .
16 years 3 weeks before #8246 by manual-mecanica
Tell me a thing when the fault that symptom has the car?
16 years 3 weeks before #8265 by manual-mecanica
Apparently it does not feel a serious symptom, only that the engine revolutions change almost impevebbly
