2003 Honda Pilot Radio Code
16 years 1 month before #7967 by manual-mecanica
Honda Pilot 2003 Radio Code published by Manual-Mecanica
Friends of the forum I am a bit new in this my problem is that I have disconnected the battery of a Honda Pilot 2003 and I grab the radio code and I do not know how Bolber to reestablish it, I have found a sticker in the drawer of El Passenger but I do not know if that will be the code, I have tried to enter but I have a problem because I can only enter the numbers of 1 to 6 and this one that I found has a number Nothing would appreciate if someone tubed the procedure. The radio is a Panasonic CQ-JH8261Z Model 39100-S9V-A100 Serial 11178225
16 years 1 month before #7968 by manual-mecanica
Manual-Mecanica Response on the Re: Honda Pilot 2003 Radio Code
Look how you generally say your code is inside the glove compartment, I think that for the numbers that are not like seven and the sero is left tight the 1 for a few seconds, there is a way that is certain, there is a page where they explain, look for it in Google and come out.
16 years 1 month before #8178 by manual-mecanica
Or check behind the ashtray (you must get him as when you clean him), at least in the Accord that had the code came there.
Greetings.
