Motor failure
16 years 1 month before #8008 by manual-mecanica
Motor failure published by Manual-Mecanica
Hello, I am Victor J, I need an opinion about an Opel Astra year 98/2000
2000 Turbo Diesel, X20DTL type engine
because what happens to it is that, the car starts Pefecto, it endures the release well, but when you try to climb it from 1500 rpm, the car begins to head, fails a lot, sometimes it lets you climb to 3000R.pm, sometimes you give it cane Sche when I try to pass from 1500R.PM, the motor management light is turned on and when I let it go to Relay
, I have blew the gasoil circuit, the diesel filter changed, cleaned the admission collead DEPRESSION OF THE ADMISSIONY COLLECTOR Everything is in order.
My question is, is it possible for me to fail the motor turn sensor?
thank you
16 years 1 month before #8015 by manual-mecanica
Manual-Mecanica response on the Re: motor failure
Yes, it is possible, but Nome seems very likely. It sounds more like an empty problem. What code does the computer throw you? Czech well the empty hoses and keep us informed. Greetings Jürgen.
16 years 1 month before #8019 by manual-mecanica
Look in my opinion, it is best to find out that code throws the check, because you will save you a lot of money because you will change pieces just by doing so, it can have to do with artas things, if you have a camonrail injection system you can have a problem in the Levante valve, it can be a flow and cut in the electronic injectors system, it is better not to guess and be safe.
16 years 2 weeks before #8361 by manual-mecanica
Check the toric joints that go in the injectors usually take a breath by these
