RCLIO2 DCI Turbo Start Failure
16 years 1 month before #8167 by manual-mecanica
Manual-Mecanica Response on the Re: Start Failure RClio2 DCI Turbo
Friends thanks for the answers. I tell you that the car is perfect, but I have to push it 2 meters and start. It does not start with the key. I change the point sensor and nothing.
I was no longer told that it can be the starter engine that is magnetisa and uncontrolled something, it is not "that" makes it hot and cold with the key. He is driving me crazy. A hug to all.
16 years 1 month before #8177 by manual-mecanica
The fault is in the injectors Common Rail you have to change injectors and problem solved greetings;)
16 years 1 month before #8181 by manual-mecanica
Hello partner,
sorry but I am not very clear about the problem,
the computer you use for the diagnosis is the clip (Renault official), because if so theoretically if it does not throw code it is because it is a mechanical failure, and I say theoretical mind even if Cadavez Arami the cars seem less theory.
Then you comment that with the Wash it does not start, nun or sometimes?
The car says that it starts in Pujon, the first always? Without having to wait or something?
You say so well that the car is going well, are you going to go?
Do you have the tension in the starter engine at the time of starting?
When you start and it doesn't start you, does the Tour the engine do nothing?
Take a curiosity, when you come to you that it does not start, close the car with the control waiting for a minute and try to have
me informed me please, because you have me intrigued
to check that the mass of the starter engine is good show is well fixed and free of slide or oxidctions
16 years 1 month before #8189 by manual-mecanica
Friend, I tell you, the car does not start with the key but the perfect turns the engine, they told me that a magnetic field can be generated that causes the knit sensor to fail. I have to try another start. It starts in a meter and is regulating without failing or anything, I try it, and I stop it, I start and nothing, the clutch long with the shipment and is underway.
I hope it is the start, in the afternoon I will put another one from one customer and I warn you. A hug
16 years 3 weeks before #8248 by manual-mecanica
Saves could review the contact sheet you want the problem this there and nothing more, as simple as that, and if you can verify the circuit of the incadecent or heater spark plugs or heater do not work.
