Power loss in Civic Dx 95
16 years 1 month before #8088 by manual-mecanica
Power loss in Civic Dx 95 published by Manual-Mecanica
Greetings from the Dom.
I have problems with my Civic, loses power and presents a failure when it starts (you want to turn off, as you drowned) and it still goes out of time when, I have ruled out the clutch, because I repair it recently and it seems to me that the failure is in the filter of gasoline or bugia, if someone has experience, with a similar case I could guide me ...
It is appreciated in advance ..
Marcos Lorenzo.
Dominican Republic.
16 years 1 month before #8097 by manual-mecanica
Manual-Mecanica Response on the Re: Power Loss in Civic DX 95
Dear friend, because of the symptom that indicates the failure of your engine would be in the air flow sensor at the entrance of the admission, it is possible that you have cleaned the butterfly and several somewhat at the close, in any case be very careful because it is delicate, greetings, hopefully serve you the explanation
and then tell me how it went
16 years 1 month before #8101 by manual-mecanica
Greetings, thank you very much ...
Thinking about it, adjusting the Power Flow of the air intake, I put my hand there, and since then comment to notice the failure. I can regulate that without giving or cause more problems and you could tell me where the censor is located ...
Thank you in advance,
Marcos Lorenzo
Dominican Republic.
Note:
The engine is a D15, the same in the photo ...
