Distribution strap
16 years 1 month before #8145 by manual-mecanica
Distribution Correa published by Manual-Mecanica
Hi how are things! I just acquired a Seat Cordoba 2005 with 55000 kms and I don't know if I should make a change of the distribution strap .. does anyone know more or less when I must make it ???
16 years 1 month before #8160 by manual-mecanica
Manual-Mecanica Response on the Re: Distribution belt
If urgent changing it ... it is done at 60000 km but not knowing how the use of the former owner changes the entire set (with the tensioners)
16 years 4 weeks before #8208 by manual-mecanica
A Seat Cordoba of 05, but what engine is (displacement, gasoline, diesel, motor type). Without these data, it is difficult to know when you have to do it.
16 years 4 weeks before #8211 by manual-mecanica
Change it and start counting the km, do not play it for a belt can be expensive
16 years 4 weeks before #8218 by manual-mecanica
Hello, because I have a 206 and now has 114000, and I have not changed the distribution strap, I take it to an official workshop to pass each revision and they have not commented anything to change it ...
