Ibiza cold air conditioner
16 years 4 weeks before #8219 by manual-mecanica
Ibiza cold air conditioner posted by manual-mecanica
I have a problrema with the heightizer of my Ibiza. I stay as hung and do not handle the trapillas only throws hot air and the feet. In addition, the temperature clock of the air conditioner has fixed temperature does not vary. The instrument box if the ventilator works and the screen marks correctly when you upload the velocity manual (which also works) thanks in advance
a greeting
16 years 3 weeks before #8241 by manual-mecanica
Manual-Mecanica Response on the Re: Ibiza Cold Climatizer
Hello, I'm not sure but I suppose if you disconnect more than 15 minutes.
Try by removing the fuse or disconnected the battery.: Cheer:
16 years 3 weeks before #8276 by manual-mecanica
solved problem by changing the climate screen. For a certain 450 euros in the SEAT less badly that I found it in the scratch. Thank you daniel for your help
