Help for electrical problem from Peugeot 605
16 years 2 weeks before #8343 by manual-mecanica
Help for electrical problem of Peugeot 605 published by Manual-Mecanica
Hello, I have an electrical problem with a Peugeot 605, you do not arrive current to the gasoline pump, I would appreciate someone to tell me where the inertia cutting interrucer is going that the problem may be due, the car is a 605 sri 1.9 i of 90, a greeting thanks.
16 years 2 weeks before #8409 by manual-mecanica
Manual-Mecanica Response on the Re: Help for Electric Problem of Peugeot 605
Generally, Ban under the chest next to the driver's pillar, you can search under the gunatar, formerly llavavan Ally, check the relief and the fuse first, you did not hit the car is difficult for you to have that problem unless you are wanding with water.
