Toruqes Citroen Ax 1.4 Model 1993
16 years 2 weeks before #8354 by manual-mecanica
TORUQES CITROEN AX 1.4 MODEL 1993 Published by Manual-Mecanica
Hello, I need to know if someone can provide me with the bulls, central benches, VIla and steering wheel for the Citroen Ax 1.4 1.993. Thank you very much for your help
16 years 2 weeks before #8411 by manual-mecanica
Manual-Mecanica Response on the Re: Toruqes Citroen Ax 1.4 Model 1993
The torques can be calculated by length and bolt width, in Google you find the tables.
16 years 2 weeks before #8417 by manual-mecanica
Your citroen is the AX 1.4 nothing more.
Citroen Ax 1.4, 1991-1993, Motor Code: K2A, Carvurado.
Phase 1: Tighten 20 Nm
Phase 2: 120 degrees, (Pry angular)
Phase 3: 120 degrees
This is for all models 1.4 but if your engine is a oil tanker with bosh or broken bosch changes the Parete I leave it anyway to see if it serves you.
Cittroen 1.4 Ax Rotodiesel and Bosch.
Phase 1: Tighten at 60 Nm
Phase 2: Loosen 360 degrees
Phase 3: Tighten 20 Nm
Phase 4: Tighten 160 degrees
Phase 5: Tighten 160 degrees
