Noise problem Cherokee Liberty KK 2008
16 years 2 weeks before - 16 years 2 weeks before #8404 by manual-mecanica
Noise problem Cherokee Liberty KK 2008 published by Manual-Mecanica
Hello, everyone.
The matter is as follows, I made a trip with my cherokee 2008 from Caracas to Bogotá (we had a lot of weight and fell into countless holes and potholes at high speed), and now it is playing a tacata that I imagine has to do with the suspension. When I check it, I realize it presents a wear in the metal piece that holds the front wheels that when crossing the direction and I imagine that falling into a hole sticks from another piece. since it presents the right wear right where the left and the right of right is marked on each wheel.
The fact is that I do not know if they are bushings, the plateau, some rubber such as the stabilizer bar, the shock absorbers or that what is already worn that makes these pieces shock when they should not do it.
I attach photos one of the wheels (both are the same) to see if they can help me, I know that in a workshop they will send me to change each and every one of the pieces until they find the fault and with the price of the spare parts I am not for unnecessary expenses.
I am also surprised that it has been damaged so fast.
Thank you in advance.
Latest edition: 16 years 2 weeks before for .
16 years 2 weeks before #8422 by manual-mecanica
Hello friend, look at the photo is fine but I don't know what Angulo you took it, the best thing you can do is see where there is another worn part that is what is making contact with that fixed part that you show, it is a wear due to displacement, but it is complicated to tell you where I can not see the vahiculo, try to see well and you warn me are not many things that can hit in that sector try the wheels turned but if it is in both sides, or some bolt that was cut or the cut of some support if you want to take more photos and send it, but anyway having the vahiculo it is very easy to realize that it produces that damage.
16 years 2 weeks before #8423 by manual-mecanica
They told me that this wear was normal, because it is like a stop where the address when crossing. Now it is the same because the noise continues.
16 years 2 weeks before #8425 by manual-mecanica
I do not think that it is what they told you is ridiculous that the Brazo of the dough is the top, I do not believe for me that there is another problem, anyway it was to devise something to avoid noise, but I believe that there is a more problem there, a displacement that would not exist, which would not stop arriving so there would stop him before.
16 years 1 week before #8430 by manual-mecanica
Hello partner, what they told you that this wear that shows in the photo, is true and totally normal since this is the top of the address, this photograph that you show is on the right side in driving position, there are several factors that can present this noise, check first that the adjustment of the address jaws is correct and that the pills have the anti -nouned plate Since they had noise such as the blow you describe, another thing that also usually happens is that the tensioning support of "differential" front "front is broken and it sounds terrible, all this can be tested by yourself with a lever of strength, gate a wheel as you want from the chassis part so that it is free, then with the hand you perform some repetitive movements up-right-right and left. It can be the direction terminals and down and below are the newspapers, this is very frequent in these vehicles, perform it with both wheels and tell me, if you need anything else you tell me, do not stop looking if the shock absorbers and rubbers of the scissors are in good condition.
greetings.
