problem access filter engine ford fusion
16 years 1 week before #8452 by manual-mecanica
Motor air filter access problem published by manual-mecanica
Hello everyone. I take my first message to present and greet you.
My "problem" is as follows: the time has come to change the engine air filter of my
Ford Fusion Trend ... The problem is that, after removing all the screws, there is no way to remove the lid. I have not wanted to make strength with the destroyer for fear of breaking it. Is there any trick?
Thanks in advance. Greetings again.
16 years 1 week before #8460 by manual-mecanica
Manual-Mecanica Response on the Re: Problem Access Filter Air of the Motor Fusion
The truth is that I remember just take out the screws and strips towards Arriva, still look if it does not have something that affirms it more aya they are hard and the hose gives it greater resistance firm but carefully.
16 years 1 week before #8495 by manual-mecanica
Maybe it doesn't come out all just get up one side, pull it with force but with careful
luck)
16 years 2 days before #8562 by manual-mecanica
Ola you just have to kitar the front screws of the front housing that are two, then you will get out of front nothing more, you will have to pull it through the rear so that it comes out, if it is put you, they are the rear tacos that are glued, then it puts something like a lever, from front to back that it reaches almost to the taco and will have the lever, by the rear. Housing and then you are going to you loose.
all the best.
