Peugeot 306 xn year 98
16 years 1 week before #8478 by manual-mecanica
Peugeot 306 xn year 98 published by Manual-Mecanica
This self -bencinero and smokes as a locomotive, black smoke, change the spark plugs chew, pump. Urgently need the workshop manual and how to read the error code :( : Dry:
16 years 6 days before #8481 by manual-mecanica
Manual-Mecanica Response on the Re: Peugeot 306 xn year 98
Friend I tell you a little in the section of mechanical problems we can help you, in the manual request section you can request your manual. I tell you the black smoke in the vehicles is an incomplete mescla either air or fuel, the best thing you can do is a complete affination to see if it improves this, change of spark plug It is important but it is the last option, if you do not have check lights or codes of Averia deveri solve your problem. If you have a brother codes or the check on the best thing not to guess it is to connect it to a SCANER, if you do not have the posivility of doing this, I recommend you check the flow and the TPS in for for it is what the black smoke probates any other query do not hesitate to ask but in the section of mechanical problems like that can help you, you can help you, there is some with the same problem and the same problem. Otherwise, greetings and take care.
16 years 6 days before #8482 by manual-mecanica
Change spark plugs, chew MAP sensor, Landa probe, I have doubts with the TPS when the sensor is disconnected and measure voltage in the plug I have 5 volts in pin A in Pin B 5 volt in pin c z zero. The question is because I have 2 positive with the sensor disconnected
16 years 6 days before #8486 by manual-mecanica
From Ahy lies the problem, the sensor is in full load and sending dema fuel, when measuring it with the aviert contact in a pin you have 5 volts, in another one fixed earth and the third should vary the voltage when moving the accelerator never llangan to 5, until up to 4.8 or there varies the range, you can measure the TPS. TPS has an internal resistance between the 5 volts pin and that of fixed ground, you specifically do not have the range of your TPS, but if there is no voltage variation between the output pin and the fixed earth is damaged if you do not save how to measure it ask me.
14 years 5 months before #18285 by manual-mecanica
Hello friends, I have signed to the forum, I need your help .... Look I have a Peugeot 306 ST, from the year 95 and some time ago it began to accelerate sometimes and decelerate itself to such an extent that the revolutions are so low and turns off, I have changed sensors between them MAP sensor (admission of the miltization), sensor tps, spark plugs, and what do they think? Keep it up ..... According to the scanner the damage was in the TPS, but I have already changed it and remains the same, help me with some clue to fix this inconvenience please, thank you !! : UNSURE:
