Help with Ford Scorpio of 98 (American Model)
16 years 4 days before #8542 by manual-mecanica
Help with Ford Scorpio of 98 (American Model) published by Manual-Mecanica
: S Hello I have problems with my scorpio, the front lights do not go but the rear yes! E reviewed the fuses but not in the problem, I have no manual with which I do not know if it has more than two boxes of fuses or where the problem may be if someone could help ??????????????
16 years 3 days before #8551 by manual-mecanica
Manual-Mecanica Response on the Re: Help with Ford Scorpio of 98 (American Model)
The front lamps having a much greater consumption than the rear do not usually be regulated by Fusobles but by relays since they are around 45 or 65w possibly the problem are the reels look for them and check them
16 years 3 days before #8557 by manual-mecanica
Look first check the relays as myhem indicates but the truth is that kind of problem, if the lights light but very short the problem is a land, it disconnects one of the headlights and food direct from Vateria with two cables and if it turns on how it should be enthaps to the problem is a land or a current, the Susukis happens to this problem because of the teleceoming Its voltage if the voltage is correct then the Earth is the problem if you do not save how to do it, just check first, greetings.
