My Nissan Sentra B14 does not give star
15 years 11 months before #8644 by manual-mecanica
My Nissan Sentra B14 does not give a Star published by Manual-Mecanica
Hello everyone, I am a rookie in this forum but I really need a help, I have a Nissan B14 XE of 2001 of 5 Change and does not give Star we already check fuses, Riley Starter Motor but does not reach Current to the Gujias. The dashboard lights light everything but does not give Star at all, this car buys it as a second one already had to immobile but it is deactivated and has no box of it.
Whoever has an opinion would be of great help.
15 years 11 months before #8650 by manual-mecanica
Manual-Mecanica Answer on the Re: My Nissan Sentra B14 does not give Star
Friend look I tell you the Nissan in general they have a problem well common that to my pareserer is what happens to you, so that it does not spark in a new car PPor is the fault of the magnet captor, or twist sensor of the Sigual depends on the country where you live, if it is in correct state check the flow that also gives this failure, the starter engine is ok truth?
15 years 11 months before #8655 by manual-mecanica
I thank you for writing to me with your opinion but if we do not have the current to the babbules there will be no spark because we would have to review the magnet captor?.
The starter engine is ready.
Thanks my friend.
Greetings,
15 years 11 months before #8659 by manual-mecanica
As a current to the valves, the valves do not use current, I briefly explain to you great features how the magnet captor works, this detects the turn of the Sigual crosses from the interruption of a magnetic field, and thanks to this send a signal towards the coils so that they shoot the spark in the spark plug that corresponds to the time, this magnet gives a spark signal and in some cases the flow Your vehicle, in most Nissan this spark function is also generated by flijometro by telling the computer that if there is air and that the engine is running, they are usually hot thread you can take it out and see that the thread or burned is not cut, but the magnet captor is the one who commands the spark in Nissan and that is what is not spoiled, check it and keep it informed.
