FORD FOCUS LX 2000
15 years 11 months before #8652 by manual-mecanica
Ford Focus LX 2000 posted by Manual-Mecanica
How my name is Jovanny and I am from Honduras
I have 2 problems with my Ford Focus:
the first is: in the engine a rudio is heard when he turned on and walk it and more than everything when the car is cold .......... After a while the noise disappears when the car is ignited but stopped and is always heard when it is running.
The second is: at the moment I go to a gas station and echo fuel at the time of turning on the car, it goes out at least as 2 times then turns on normal and works well until I return to load fuel again !!! At certain times I also feel that when I accelerate the car, it tends to pull a little but it is not always sometimes.
They could please help me !!!!!!!
15 years 11 months before #8658 by manual-mecanica
Manual-Mecanica Answer on the Re: Ford Focus LX 2000
Hello, look the engine noise can be many things that listening to saver and forbid it, because of the fuel, I believe that with a cleansing the fuel tank you solve the problem.
9 years 3 weeks before #51178 by manual-mecanica
Manual-Mecanica response on the subject Ford Focus LX 2000
Good afternoon, where can I download a manual of the Ford Focus LX year 2000 engine split
9 years 3 weeks before #51179 by manual-mecanica
How about Jovanny and Honduras
my name is Miguel. I am from El Salvador.
I answer your questions in order I hope it's not too late.
1) I have a Frod Focus Year 2000 Motor 2.0 LX Split.
I can tell you that it is an excellent car when you give the maintenance that the owner sends, the noise in your engine already lived it and it is a bus that is worn the packaging, and it does not reach enough oil when it is cold, you have to change, it has to be a mechanic that knows,
2) This problem is given because the gasoline pump is already very old and dirty and does not reach the gasoline well to the injectors, since these cars work. Injector, you have to buy it, at my cost $ 108.00 dollars plus $ 20.00 of the installation, and I put a bona of the Ford Explorer and I no longer have problems.
I hope it helps you.
