Air-conditioning
15 years 11 months before #8930 by manual-mecanica
Air conditioning published by Manual-Mecanica
Hello, I would like to know if to replace the air conditioning evaporator of the Nissan first year 2000 you have to lower the board, I thank who can give me that information.
Greetings from Panama
Vic
15 years 11 months before #8948 by manual-mecanica
Manual-Mecanica response on the Re: air conditioning
Hello partner, you can try to disassemble without removing the board but it is very laborious and some element can be damaged, the easiest thing is to remove the board is also much safer luck and greetings.
15 years 11 months before #8979 by manual-mecanica
Manual-Mecanica Response on the Re: Re: Air conditioning
FRIEND DEVES Yes or if the board does not come out and it is easier to get in the end you will take less.
15 years 11 months before #8987 by manual-mecanica
Thanks friends, I got who took the evaporator without disarming the board and I only take 30 minutes, already bought the components of the air and ready to install.
Thank you again for your contribution,
Vic
