- Thanks received: 1
06-19-2025 Hits: 895 Technology
That problem you have is for the alternator, you have to check it, so that you are sure to start the vehicle and with this walk it disconnects the battery if the engine stops the problem is an alternator, that if you do not have a tester, it is not highly recommended to do it, if you have a test tester check how much load
