Mazda 626 when IZ stops
15 years 10 months before #9080 by manual-mecanica
Mazda 626 When IZ stops published by Manual-Mecanica
Hello friends, I hope you can guide me in this detail, the thing is this, I buy a automatic Mazda 626, and I was shocking it, I repair the motor, the bad thing about this is that when I rotate only to the left side the engine loses power and ends up stopping so that it does not stop I must turn off lights and keep it accelerated when I do not reach to turn off lights simply stop once stopped once I put the pair I put the pair. Someone could give me an idea
to boys is of hydraulic direction. I would appreciate them in advance: S
15 years 10 months before #9084 by manual-mecanica
Manual-Mecanica response on the Re: Mazda 626 when IZ stops
Hello, for what you explain, the safest thing is that you have some loose mass cable check one or perhaps you forget to connect any, also check the inertial switch possibly this defective test to step on your finger on the red lid to see if it is well placed
15 years 10 months before #9340 by manual-mecanica
Thank you very much for responding to my consultation friend found the problem was a client's panne the man gave him so much oil in the engine that left it heavy and this was out of me that he stops thank you and we are in contact, the answer is appreciated
