PEUGEOT PARTNER 1.9D ELECTROVENTILER
15 years 10 months before #9324 by manual-mecanica
PEUGEOT PARTNE 1.9D ELECTROVALADOR PUBLISHED BY MANUAL-MECANICA
Hello good morning, I have a Peugeot Partner 1.9 D of 2003, and I do not know what the problem is, it heats up, I have changed the thermostat, the thermocontact, I took out the electro -ventilator since I did not skip, thinking that it would be broken, but it works, I have also changed a resistance of the two that we carry on the grill of the electro -ventilator support, and even so, the electrventilator does not jump. I can already be, necechesitoo please! I leave my email since an answer urges me .. , is the company's van. Thank you very much greetings
15 years 10 months before #9325 by manual-mecanica
Manual-Mecanica Response on the Re: Peugeot Partner 1.9D electrventillator
Hello partner, did you check fuses and the electro relay? It controls those items to see that they are in order and also controls the thermostate, luck and greetings.
15 years 10 months before #9338 by manual-mecanica
Locate the temperature sensor disconnect it should enter the fan direct : Woohoo:
