Suzuki Samurai, problem with the lights
15 years 9 months before - 15 years 9 months before #9698 by manual-mecanica
Suzuki Samurai, problem with the lights published by Manual-Mecanica
Hello, I have a 1995 Samurai Suzuki and I have the following problem: the left front focus barely illuminates. Turn on, but with a very low level. Change the outbreaks of position and the bad is still the left, so I think it is not a problem with the focus itself.
Any idea?
Thank you!
Last edition: 15 years 9 months before by .
15 years 9 months before #9699 by manual-mecanica
Manual-Mecanica Answer on the Rezuki Samurai, problem with the lights
Hi Goite, so you comment on that lighthouse, you lack the dough set and clean the mass terminal, greetings.
15 years 8 months before - 15 years 8 months before #9723 by manual-mecanica
Thank you very much for your jal answer!
Check the terminals and are clean and correctly connected.
An additional fact: the left focus gradually lowered its intensity and yesterday night it went out completely. The right focus has also turned off.
But I managed to find the problem: they were the fuses. I burn the left and then burn the right.
Thanks again.
Latest edition: 15 years 8 months before by .
