Mazda B2200 turns oil light
15 years 9 months before #9702 by manual-mecanica
Mazda B2200 turns on oil published by manual-mecanica
Friends, I have a Mazda B2200 R2 Mazda truck that for a while now turning the oil indicator light, if someone has the electrical diagram I would appreciate it ... :)
15 years 9 months before #9703 by manual-mecanica
Manual-Mecanica Response on the Re: Mazda B2200 Turn Oil Light
Hello friend, first take the oil pressure, if the indicator bulb is fine, when when you get old, you usually present that fault, by the manual test in these pages, bookaller.net and automecanico.com, you have to register but it is easy and free, I hope it is helpful, a hug.
15 years 9 months before #9706 by manual-mecanica
Thank you for responding, initially when starting in cold turns, then it goes out, I take the precion taking the bulb of cold oil 65PSI and when it heats 45psi it goes out, now it does not go out, the one that is firing is not the bulb, it is the precion valbule and I am not afraid and I am worried to continue using like this ..
