Problems with the start of Peugeot 206,
15 years 8 months before #9922 by manual-mecanica
Problems with the start of Peugeot 206, published by Manual-Mecanica
I missed the key with the electronic code, and they made a copy of the key, but it only allows me to open the doors and I cannot start the car. A friend told me that he saw in this forum a comment on how to make a bypass to the key code reader. I would like to know if possible and how to do it. Since thank you very much. Denys, Punta Arenas -Chile.
15 years 8 months before #9923 by manual-mecanica
Manual-Mecanica response on the re: problems with the start of Peugeot 206,
Hi tell me what model is the Peugeot? Is it naster or diesel? I ask this because if it is diesel with conventional injection pump it is easy to cancel the immobilizer and if you do not have to code your new key.
Claudio.as forum
15 years 8 months before #9925 by manual-mecanica
What engine has, with that information I can help you, and if it is diesel it is and it is not easy but more cencillo can be made than the gasoline, these must be recorded the key or you can cancel the engine's computer scarf.
14 years 1 week before #22970 by manual-mecanica
Hello, I was reading this issue because I have a 1.9 diesel duchato with problems to start, I do not turn off the code light when I put the key, I was trying to bridge the immobilizer but I did not have a positive result, he would need if they can help me to bridge it as it should. Thank you very much !! 1
