Problems with the convertible hood of Mini Cooper
15 years 8 months before #9991 by manual-mecanica
How about friends, I have a problem, I hope you can help me ... I have a convertible mini coopestable, the process to remove the hood is controlled automatically from within, it is done in two steps, the first step opens the roof as if it were a burning and the second one lifes it completely and keeps it to be completely convertible, my problem Aydua, thank you very much !!
15 years 8 months before #10003 by manual-mecanica
The first thing you should do is check the control or actuation sush, kisas the second contact is not working, the electric part in the first place and warns how you are going.
15 years 7 months before #10484 by manual-mecanica
In Princepio these vehicles have problems in the drag engines that are mounted in the trunk, they are failures that have occurred in many of them, if you break you at all you will have to change guide and cables too, I recommend that you check it as soon as possible and meanwhile do not try to open the capota or it happens to my client that you have to change everything for the modic price of 2400 euros, luck
11 years 10 months before #42901 by manual-mecanica
Manual-Mecanica Answer on the subject problems with the convertible hood of Mini Cooper
Hello, did you already check the fuses? Then check the operation and state of the hydraulic electro-motor in the part of the left-handed trunk, check that it is not burned or damaged. I am not sure that fuse is for the hood I will check.
