Butterfly body for admission
12 years 3 months before #40776 by manual-mecanica
Butterfly body for admission published by Manual-Mecanica
I need data and ideas on how to make an individual admission system by injection cylinder
12 years 3 months before #40782 by manual-mecanica
Manual-Mecanica Response on the body of butterfly for admission
What engine do you have?
Because if what you want is something simple you can put in the admission collection near the cylinders some injectors mounted on a Ramp of the Seat Cordoba type
of 99 and a Hall collector in the camshaft, with an electronic module that tells them what momnd should have had.
Note: The only aberration like the one that your Sujieres, in Spain is a Ford Mustan of 67 V8 with mono -to -side injector a barbarity to make it work and works very badly.
But nobody tells you that you can't do your do it and alomejor you get it to work
11 years 6 months before #44243 by manual-mecanica
Hello, if it were to carburement, you would win in simplicity, absence of breakdowns, reliability, remember that the carburetors "do not think" but obey the pedal, if they are well regulated. Adapt an injection like the one you want needs enough variables, collectors, manage without caudalimetro in multiple, etc.
