Hi Jabier, I don't know what you mean with "5 valves" ... will be 5 speeds ... This 8 -valve and 60 hp engine shares the same block as the 100 hp, but not the same pistons, nor the cylinder head (16 valves) or electronics (switchboard or equ) with which, I do not intend to discourage you, simply tell you that there is no "tunning" that is worth the engine. legal) or buy the 100 hp directly, I already say, add valves to a cylinder head ... You should look for more information and you will see what I tell you. Greetings!!
