Peugeot 206
14 years 7 months before #17196 by manual-mecanica
Peugeot 206 posted by Manual-Mecanica
SYMPTOM: Motor in irregular relay, noise in the non -continuous escape, bad smell in the
diagnostic exhaust: Ignition coil with cut field or leakage escape
repair: change of coil there is no more
this applies to all the Peugeot with direct coil towards the spark plugs, they are coils from new ones fail is the main guilty of the irregular walk.
7 years 11 months before #52381 by manual-mecanica
Manual-Mecanica Response on the Peugeot 206
Exactly, repair with coil change must be solved.
