For those who have a power system error signal, Theft System, of Chevrolet Cavalier LS 97 Motor 2.2 A possible solution is as follows:
the Cavalier does not use chip in the key but if a sensor in the cylinder that must be programmed when changing.
If the light on the board (Theft system) flicker must be re-programs.
In several forums they indicate different methods but the most common is as follows:
the engine
(it will not light) and then leave the key in the march position, do not pass it to off
10
to stop the
light of
blink
