Opel Corsa, 1995
15 years 6 months before #10893 by manual-mecanica
Opel Corsa, 1995 published by Manual-Mecanica
Hi Foristas here, I have a problem with an Opel Corsa year 1995, a double camshaft engine, and 1.6 GLX engine, the injection system of this vehicle is a multitec S 95, multipunto, the command unit or ECU is 16213739, and the manufacturer's code is RQ, the problem is the following this vehicle From Heror -19-, a sign signal of RPM, tells me badly or missing, and that it is a memorized breakdown, the problem is the following this engine that is x 16 xe, it has a camshall and another of follow, if any of them were in poor condition there would be no spark and the engine would not start, change the sensor of the camshaft and the engine starts and the engine starts and it goes well but it goes well but it goes well but it goes well Check and with the same code, if someone had something similar with a Corsa or another vehicle please answer to get an idea of ​​the detail since I do not have a computer from the same vehicle by hand to project, thank you.
15 years 6 months before #10897 by manual-mecanica
Manual-Mecanica Response on the Re: Opel Corsa theme, 1995
hello,
Code 19 is effectively for the crankshaft sensor. The car must start even if you distrust this crankshaft sensor. Yes, you will give you failures with high revolutions or it will not rise more than the ~ 4500 rpm as well. The wiring and the signal sent by the ECU, they are Pin A13 and! A14, the first no more than .3 v giving and the A14 must have ~ 4 v in idle. You attach the oscilloscope wave greetings.
15 years 6 months before #10904 by manual-mecanica
That such lords I have had such a problem and it is not the first my solution was to change the crankshaft sensor, in which a sporadic short was produced in certain conditions, anyway the wiring of said sensor to discard is not to verify.
all the best.
15 years 6 months before #10913 by manual-mecanica
Hello Kikemec, I share what the companions say, I would exchange the sensor directly after checking the wiring for the doubts, but it is made that the failure is caused by the sensor, but if the code 19 throws you, I hope you can solve it, a hug. : Cheer:
15 years 6 months before #10945 by manual-mecanica
How kikemec,
how did you go with your Corsa? Greetings.
