Motor failure
14 years 10 months before #15530 by manual-mecanica
Manual-Mecanica Response on the Re: Motor failure
What auto are they talking about? What engine has the vehicle starts or not? If you have three cylinders without working the car is not going to start? If the spark plugs come out black and not wet then they are running and you have a fuel exile, if you have bad valves you have bad comprehensive and also against explosions towards admission or escape.
14 years 10 months before #15536 by manual-mecanica
It is a Saturn Vue 2003 3.0 DOHC.
14 years 10 months before #15545 by manual-mecanica
If they come wet, the first thing you should verify is whether there is a spark
14 years 10 months before #15563 by manual-mecanica
They hear and why we don't start from the beginning, what if they are the spark plug cables? In my Nissan Quest I had that same problem, the spark plugs (and dry) came out, and it turned Failure perceived then you have to look for him, they can even be the injectors, but first the first, to see how you go.
14 years 10 months before #15633 by manual-mecanica
What vehicle is it?
Do you have a spark in the cylinder cables that fail?
did you check their compression?
Is it with a distributor or is you with ecendido dis?
Tyrans some data have site we can help
a hug
