Lord, colleagues or classmates, well waiting to have a good reception, I expose my problem, it turns out that I have a Peugeot Boxer 1.9 year 2001 that so that it can start reading a code that brings the key through an antenna, and that it goes to a module located under the direction column, well the problem is that the key has been lost and there is no way that the engine starts and I would like to Get the engine to turn since I have intervened the contact sheet Mais ne démarre-t-il pas parce que l'ordinateur ne lit pas le code de clé de sauvegarde qui signe refuse le moteur afin qu'il ne commence pas afin d'inerter inwly ces méner externes et de pouvoir quitter le moteur? Tout commentaire sera reconnaissant merci
