Bonjour
avec l'entonnoir, vous devriez pouvoir le mettre; Alomejor you have the wrong funnel and you need another bigger one, if it were adequate (the one who covers your head), check it a lot of oil to slip well, or fat, if you still could not put it there is a tool that is pneumatic that opens the
overal Inside a steel frenulum, once it is removed with a nylon hammer and some taps it must come out, put the new overalls, with some taps you put the head of the stick making sure that Le frein est bien pris, il est plein de graisse et le maintient avec les pinces qui viennent normalement à vous dans le kit poussiéreux.
Salutations
