Hello Nesty, it helps with the Peugeot 206 loses power in the pique (when you want to revashed like a cascade and this is done by seconds then reacts) the accelerator is sensor does not bring accelerator cable, which was washed the manager eliminating moisture of oil, clean the body of the accelerator sensor, clean the escape FAP, gasoline pump, gasoline pump brand 55lbs, with all this does not I manage Para melhorar uma ideia com antecedência, obrigado.
