Olá Henry, vejo seu comentário, mas quero saber quais condições o carro chega, é sinistro ou não tem chaves, ou elas caíram na água? Eu não começo de dia a dia?, Ligue o quadro? Indo,? Você tem código de falha? Because the Aut Mar March ignition system depends on the NATS system, and if it is evil or does not work, it stops sending a signal to other components, the first thing that I would do would be to scan and verify failure in the NATS system and if it is not because there is verifying gasoline PRSION, because the electronic ignition works with Can CAN system throughout the system checks and comments and seeing if I can support you in your problem, ok luck
