Pesquise no MDM
Boletim
Problemas com Astra
  • Autor do assunto
  • Pensionista fresco
Avançar
11 anos 2 meses antes #46053 por Manual-Mecanica
Problemas com Astra postados por Manual-Mecanica
Good morning colleagues, I have a problem with an Astra 2005 automatic, the transmission was more than a month ago, because it was burned and skipped, it was well, then the user tells me that he listened to him and felt a blow, which was solved by changing the rear support because he was damaged, he repairs both days, he tells me that the TC lamp The car, throws the P1700 code regarding the traction control module, washed and adjusted the burns connected Para o trans, honestamente, não sei o que mais verificar para que, se algum colega puder me orientar, seria apreciado.
muito obrigado
