Friends Sorry I did not see me agreed on the solution of the Corsa de some Tienpo behind, it happens that all these models bring signal captor to the crankshaft, do not ask me why, but the key is eaten to the keterus, well that is a detail, the central bolt of the Danper is released devoted to this fault and the pulley is with a little game, it is not much but this has and this is left Point, you tightly presses the bolt and this problem solved, it is Tudo, mas a farsa quando eles o enviam e a retificação segue, porque se não estiver no local no local em que o veículo não sai mais. Boa sorte e saudações a todos.
