Problemas de iluminação Hero Honda CBZ 160, preciso de ajuda com esse problema e como corrigi -o.
10.84 volts barely arrive to the front lampping connector, the bulb is 12V/35W which barely illuminates its intensity is not like that of other motorcycles, they told me that it was the regulator and changed it but I do not improve at all, continue with the same voltage and intensity, since I am eighteen that this type of motorcycle takes the voltage of the coils and not directly from the bacteria Or as I do to know if the As bobinas geram amperagem suficiente para o carregamento desta lâmpada, o que devo fazer para poder resolver esse problema, espero que seus comentários,
obrigado
