Pesquise no MDM
Boletim
Problemas com o golfe A31.8
  • Autor do assunto
  • Pensionista fresco
Avançar
14 anos 9 meses antes - 14 anos 9 meses antes #16258 por Manual-Mecanica
Problemas com o Golf A31.8 publicado pela Manual-Mecanica
Hello everyone I have a problem with my car a golf A3 1.8 it turns out that when I start it well and everything but when accelerating it between 1000 and 2000 rpm it makes the injection cuts and when accelerating it to more than 2000 it takes away the fault that does so for a few seconds later I accelerate it in that range and does not present the failure itself is presented when it is started and in the scanner nothing can be: Seco: ? Minha bomba de gás ou o computador será? Espero que você possa me dizer sobre minha dúvida:)
Última edição: 14 anos 9 meses antes .
  • Autor do assunto
Avançar
14 anos 9 meses antes #16286 por Manual-Mecanica
Resposta Manual-Mecanica no Re: Problemas com Golf A31.8
Normalmente, esse tipo de falha é apresentado pelo sensor TPS (aceleração), mas se você não apresentar a falha em outro momento, poderá ter um problema com o sensor de temperatura
  • Autor do assunto
Avançar
14 anos 9 meses antes #16287 por Manual-Mecanica
Well, the truth is already checked and the tps were changed to another although the one who got used is used and the same temperature already changed it as 3 times something else that I have detected is that as the car had a good time it detects that my gas pump Now do it at normal temperature, you leave it 10 or 20 min, you try to start and take something else that is detected is that the spark plugs come out black and with a strong smell of gasoline that something else would you can advise me to check?: Seco: saudações:)
