Pesquise no MDM
Boletim
Daewoo eu espero 1500cc
  • Autor do assunto
  • Pensionista fresco
Avançar
14 anos 9 meses antes - 14 anos 9 meses antes #16318 por Manual-Mecanica
Daewoo, espero que 1500cc publicado pela manual-mecanica
Hello, I have a Daewoo I wait 1.5 year 94, when I leave without problems like 25 min and after that it starts to pull as if it starts to run out of benzine (it has benzina), when I give AARANQUE it is about 1000 rpm then after minutes lower than 500 rpm and if not accelerated the engine stops, it passes me several times in arrests of the vehicle, they told me that they could be Spark plugs, I have changed spark Plugues, cabos de vela de ignição, bomba benzina, filtro benzina e nada. Eu preciso de ajuda, por favor.
Última edição: 14 anos 9 meses antes .
  • Autor do assunto
Avançar
14 anos 8 meses antes #16327 por Manual-Mecanica
Resposta Manual-Mecanica no Re: Daewoo, espero 1500cc
I believe that your problem is a bit simpler than that, if your problem is hot revolutions, you have to check first of your IAC valve first, after realizing a cleansing of it, you see whether it improves or not, if it does not improve then with the auto in working temperature I suffer a little the revolution from the pedal adjustment screw, since the normal thing is normal for that vehicle is between 850 RPM, at working temperature, it is normal for these revolutions to be between 1500 and 1700 rpm, é mais em Toyota Yaris, ligue para 2000 rpm e cai progressivamente na função da temperatura, pois as revoluções são tão baixas em alívio tendem a interromper o motor.
