Saudações a tudo o que preciso da sua ajuda,
tenho uma falha em um mod do Ford Mustang. ´94 3.8 LTS V-6, on electronic without distributor with a 104-pins computer
in the minimma lav PSI, to the Data line in Scanner gives the barometric pressure of 93.5 kPa, and a frequency of 150 Hz, already probate with another MAF sensor, and the failure is the same,
if someone can help me I will appreciate your attention and your time thank you
