Good friend Diesel type fuel engines (which is that of your car) has an injection pump that is responsible for measuring the exact amount of fuel that will be injected into each cylinder usually the diesel fuel is less durable than gasoline (in case you are comparing it with a carbure Calibrating injector by injector ... It has to be a person who knows what he does and apart that you know how to do a good calibration job if it cannot be worse in case the poorly A bomba calibrada deixa você, verifique as velas de ignição, uma a uma, e veja bem se forem queimadas na parte que entra no cilindro, onde a ignição é formada se forem queimadas, há uma combustão ruim e se o motor estiver sendo acelerado
demais
