Hello, my corsa presents the following failure:
When the doors are closed with the key the system does the system but the right back door does not close and I have to close it manually, the strange thing is that sometimes it works and other times not, I have checked fuses I have reviewed the driver's door thinking that there is the fault, but it remains the same, I am still the same, I need to disassemble the door that does not work but I have not done it since I do not think the problem is not Lá, onde está o famoso módulo, se alguém souber que a falha seria grata.
